Who has an intercooler behind the grill of their 99-02 truck?
Old 03-28-2019, 10:35 PM
  #61
A4edwin's Avatar
So Where does everybody mount the trans cooler stock or aftermarket? Tricks website tells you to move it but that’s it.
Old 03-29-2019, 06:52 AM
  #62
Truck Sponsor
TrickTurbo's Avatar
most of the time it goes in front of the intercooler.
Some truck can go behind where others put them under the truck with fan.
Old 06-17-2020, 02:27 PM
  #63
ALL ULL C's Avatar
Old thread bump.
Just looking around for more A2A setups behind the grille on 99-02 while keeping the A/C condenser where it's at. I have my eye on a 4.5" thick core for my Twin setup and so far it looks like post #8 from Beatdown is the direction I'll have to go with the grille.
Old 06-17-2020, 07:27 PM
  #64
Talstar's Avatar
Default Went with a 2500 core support. It’s a 2005.
Intercooler and transmission cooler
Old 06-18-2020, 11:23 AM
  #65
bmxarmy's Avatar
I was able to fit a 5" intercooler into mine. AC condenser would fit behind the IC and infront of Rad but I ditched AC.
Old 06-18-2020, 12:33 PM
  #66
ALL ULL C's Avatar
Nice! I'm still assuming you've had to trim the grille? Did you need to trim the bumper any? That is exactly what I would like to do with this TT intercooler and run the outlet down below the support and back up to the TB. Is that bar between the bumper mounts OEM?
Old 06-18-2020, 06:10 PM
  #67
pknowles's Avatar
I have a 3" trick inter cooler on my 2001. I made brackets and mounted the trans cooler beside the inter cooler (passengers side), not in front of it. It just fits.
Old 06-19-2020, 01:15 PM
  #68
ALL ULL C's Avatar
Yeah I'll most likely relocate the transmission cooler maybe down low or under the truck with a fan on it. I'll have all kinds of room where the OEM fuel tank won't be anymore as I have a DB Rods cell being built. If I go smaller thickness core I need to go longer hot length in order to support the same HP so that still may be a possibility. Ideally as I haven't had my front grille/bumper off yet is to know what room there is width and depth wise going in between the bumper mounting brackets. So can I fit a 4.5" thick by 20" wide (width wise across the radiator) and down into the frame and out the bottom or could I go with a 3" thick core and 24" wide and still fit through there. I know Trick mounts all his newer style IC's in that they come up from below the bumper and into the grille area but don't know how wide they are on the end tanks as that could give me an idea on which cores to pick out.
Old 06-20-2020, 12:50 PM
  #69
pknowles's Avatar
Not the best pics.
Old 07-01-2020, 10:57 AM
  #70
randybill's Avatar
Do you have a link to your build?
Is your truck a 1500 or 2500? I was under the impression that a 2500 rad support wouldn't fit a 1500. Thanks,
Quick Reply: Who has an intercooler behind the grill of their 99-02 truck?
