Who has an intercooler behind the grill of their 99-02 truck?
For those of you who have mounted the intercooler behind the grill of their 99-02 truck, could you post some pics and specs on your intercooler? I am comfortable cutting up the hood latch support to fit an intercooler, but would like to know what size can fit? I am hoping to not have to move the radiator back.
Thanks! :burnout: |
2 Attachment(s)
1 Attachment(s)
Attachment 149086
32x14x3.5 core with dual 3" inlets and the single 4" outlet... I had to lose the hood latch and notch the bottom core support but other than that I slipped right in |
How do you keep your hood down, mitch?
Originally Posted by Atomic
(Post 4867037)
4" thick, 3in/3out ebay intercooler
I'm rocking a eBay 31x11.5x3 with 3"in/out. Barely had to trim inside of grill shell for a good fit
Originally Posted by lglowe
(Post 4867130)
2 Attachment(s)
About the same i/c as Atomic. 4" thick, 30x12, 3" in/out.
Attachment 149084 I'm going to run this cut all the way out so it blends in. Then I'll color-match the grille. Attachment 149085 |
Originally Posted by Beatdown Z
(Post 4867262)
Yea, if you look in the first pic, you can see how it sits under the cut support, like Atomic's. You can also see the two L shaped pieces i made that tie it into the support. There's also two tabs I bolted on to the bottom of the core support to bolt the intercooler too.
