Who can beat my Radix IAT's??
Old Mar 31, 2006 | 11:15 AM
  #21
dc_justin's Avatar
Hello Dave
This post got me thinking about my IATs yesterday and why they were sitting at 80* above ambient and higher when building boost. Checked mine out and sure enough, no coolant flow. Fortunately, pulled the inline fuse I installed and re-installed it and it works great again.
Old Mar 31, 2006 | 09:22 PM
  #22
KySilverado's Avatar
Originally Posted by thunder550
I can still use it to do some good WOT tuning, which was my intention tonight anyway. I'll just have to go again in a week or two
KYSilverado....what are you planning to put in to verify flow? I might do the same but I dunno what I would put in there...
Dunno yet. Like MJ said. Some kind of flow switch. I'll let you know what I find.
Old Mar 31, 2006 | 09:52 PM
  #23
XLR8NSS's Avatar
Adkoonerstrator
Couldn't you just put a relay for the LED on the intercooler pump ground wire?
Old Apr 1, 2006 | 02:33 PM
  #24
thunder550's Avatar
High on diesel fumes
I'll mess around with it. Ordered a new pump today.
Best run last night was a 14.01 @ 98 mph, 2.08 60', 180 somthing IAT at the end of the run, 19* timing, full street trim, first time at the track with SD tuning and the 2-bar map. Not too shabby. Kyle beat me though 13.83 @ 98. The little butt-mount turbo 4.8 hit 13's and I couldn't
Old Apr 1, 2006 | 02:55 PM
  #25
kbracing96's Avatar
Ha, ha,
Old Apr 1, 2006 | 02:59 PM
  #26
vanillagorilla's Avatar
What was your 60ft Kyle?
Old Apr 1, 2006 | 03:14 PM
  #27
kbracing96's Avatar
My best was a 2.08, then a 2.14 and a 2.15. I can't get this thing out of the hole. Lanches with 5lbs of boost and 2900-3000 stall, but still won't pull a good 60 foot. I think the Z06 cam is hurting me there. Pulls good up top. The meth also gave me about another pound and a half of boost on the same wastegate spring.
Old Apr 1, 2006 | 03:17 PM
  #28
F8L Z71's Avatar
Hvae you tried bosting higher or will it let you? I found 5psi was like the cutoff limit for a good launch. Anyhting around 5psi or lower it was complete crap but over 5psi was awesome.
Old Apr 1, 2006 | 03:35 PM
  #29
kbracing96's Avatar
5psi is about all I can get pushing on both pedals as hard as I can unless the turbo is really hot.
The 4.8, just doesn't have that low end torque I need for a good launch.
Old Apr 1, 2006 | 03:39 PM
  #30
F8L Z71's Avatar
Maybe you can try using a turbo blanket to keep the turbo hot and maybe coat your exhaust to help trap the heat. I was planing on trying this on my truck before I did the swap. Anything to help spool up time. That 4.8L can have more than enough TQ to get things going if you have enough boost at launch and have the truck tuning set up right with enough timing down low.
GMCtrk
Jan 27, 2016 06:47 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
JordanH
Oct 3, 2015 03:59 PM
bagged7104SS
Sep 24, 2015 08:42 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
