whipple harness?
Old Jun 26, 2008 | 03:48 PM
da_vato's Avatar
Default whipple harness?
What does the wiring harness go to on the whipple? Is it a baypass valve assist? or something like that
Old Jun 26, 2008 | 05:42 PM
MikeGyver's Avatar
Extensions for the TPS and idle motor, a wire to the bypass valve solenoid, wires for the Whipple injectors, wires that piggyback some factory wires for sensors, and power for the system. Did I leave any out, fellow Whipple-ites?
Why do you ask?
Old Jun 26, 2008 | 06:21 PM
SincalT/A's Avatar
All those wires go in the trash as far as i'm concerned.You will not even scratch the surface of the blower potential with that stuff installed.If you can afford it go with injectors and a custom tune.
Old Jun 26, 2008 | 08:39 PM
da_vato's Avatar
Im talking about the wires coming from the bottom of the injector. I pulled all that crap off put some injectors and currently working the tune but my boost doesnt push past 2-2.5psi. So I was wondering if the bypass valve is electronic or electronic assisted.
Old Jun 26, 2008 | 09:14 PM
SincalT/A's Avatar
I should be clear that you do need the extension harness for the tps,and iac.
My bypass has no wires to it but,I do have the older style two belt system.If you have a electric actuator you might have to get rid of it and go with the older style.I am really not sure though.If I get a chance I will stop by my dads and check his kit to see if there is a way around the electric bypass.
Old Jun 26, 2008 | 09:27 PM
gao8302's Avatar
Coming from an ex whipple owner this thread has everything you need to know about the whipple and the electronics.
https://www.performancetrucks.net/fo...whipple+bypass
Old Jun 27, 2008 | 08:06 AM
da_vato's Avatar
the only thing is those are all old systems whipple redesigned its supercharger a few years back. And no one answers what that those wires are coming from the bypass valve.
Old Jun 27, 2008 | 11:08 PM
da_vato's Avatar
I pulled the vaccum line off the solenoid today. Instant boost. I guess that solenoid is electric assisted and opens when the whipple craptronics is pulled off.
Lthompson
Oct 2, 2015 12:45 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
whippledstepside
Sep 17, 2015 05:02 AM
