Whipple Dyno results
Old Sep 2, 2009 | 10:37 PM
  #21
Bromaguire's Avatar
Originally Posted by MikeGyver
When I installed my intercooler without changing the tune, my 8° of KR went away. It turned out the tune was conservative because of the high IATs, and even more timing could be added because of the intercooler.That sounds similar to your situation.
Ya theres no doubt the intercooler has helped dramatically. I also don't notice heat soak like I used to.
Old Sep 2, 2009 | 10:45 PM
  #22
dc_justin's Avatar
Hello Dave
Originally Posted by Bromaguire
I believe my wheel/tire weigh around 90lbs. So does that mean I'm losing about 180ft-lbs with them? What does a stock wheel/tire weigh?
Up to. You have up to 90lbs that has to be rotated at a distance of 1' from the center. I say up to because the weight is distributed across that entire distance and is not held entirely at that 1' mark. The weight of the wheel centerpiece needs to be taken into account.
I suppose to calculate it precisely, you'd need to perform some integral calculation to determine the sum of the weights across the span.
A much easier method would be just to do two runs, one with stock wheels, one with the 24s.
$A_Money$81
Mar 27, 2023 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
