Whipple build..Pistons,8rib pulleys and 100mm idlers??
#22
If I was to do it over, I would buy a direct drive whipple with larger displacement and have nitrous bars installed. Still wish I would have tried this with the little 2.3. Man was it snappy! Lots of fun on the street.
#24
When I went through this with whipple they told me there were 2 different snouts for that application, and only the later one was compatible with any 8 rib pulley they made since they dont normally make an 8 rib for the truck kits. I told them my serial number and they said I needed the other one ($500) on top of a new pulley ($160), so I went the custom pulley route instead (<$200). I guess you had the other snout than me.
For nitrous bars, you mean like this?
#25
So I did contact Whipple today and they do in fact make a 8 Rib pulley for my 2009 Sierra Denali 2.3L whipple setup. The part number is SCP-83000. (3" 8-Rib).
Razor I'm thinking I want to get with the Tensioner that you listed just because then I don't have to fab a 3/4" spacer, Can you tell me where I can buy an 8 Rib pulley for the tensioner you used Dayco HD Tensioner 89393??
#27
#29
I designed that spacer plate and had it waterjet out then sent it to nitrous express and had them to the bars. They are good up to about a 250shot and work great at the 150 level I have them right now. The blower inlet was already ported by someone when I got it. The 2.3 is small but it has some fight in it!
#30
