where to hook boost gauge up at
Old May 23, 2006 | 05:15 PM
blue00silverado's Avatar
Default where to hook boost gauge up at
just like i said where do you guys hook the hose up at. thanks
Old May 23, 2006 | 05:20 PM
thunder550's Avatar
High on diesel fumes
What's the application? Magnacharger? Whipple? Turbo?
Old May 23, 2006 | 05:28 PM
turbo sorry
Old May 23, 2006 | 06:05 PM
gao8302's Avatar
I have a supercharger setup. Should be the same. Mines hooked up to the fuel pressure regulator vaccum line. That will give you both vac/boost.
Old May 23, 2006 | 06:14 PM
Mort's Avatar
Cool
There is a nipple to the rear of the intake manifold on the passenger side to the rear of the cross over pipe for the fuel rail. You have to take the engine cover off to see it. It is just under the lip of the engine cover. You cut or break ( be careful) the end off the nipple and you can attach any vac/boost operated equipment to it with 1/4" hose.
Old May 23, 2006 | 06:18 PM
gao8302's Avatar
why do that when the fuel pressure regulator is much easier. Thats how mine is hooked up and it works perfect. No cutting at all just have a barbed tee fitting and a 2" of 1/8" tubing. Its very easy not need to remove the vortec cover at all.
Old May 23, 2006 | 06:20 PM
greentahoe's Avatar
I dont have the rear nipple on my LS2 and Im using the FPR for meth and boost gauge. Anyone have any pics of where to tie in for the brake booster?
Old May 23, 2006 | 06:26 PM
gao8302's Avatar
There is too much talk about nipples!!! ....
Old May 23, 2006 | 06:53 PM
can't find it exactly what does it look like.
Old May 23, 2006 | 06:59 PM
TIM Z's Avatar
11 sec. Truck Mod
send a pm with your email and i'll send you a picture!
