When would you refresh your Radix?
Old Mar 28, 2008 | 12:31 AM
  #21
La Riddler's Avatar
Fixed it. Thanks Q8 6.0. I found a thread by you and found it very helpfull. No more play.
https://www.performancetrucks.net/fo...x+oil+capacity
Old Mar 28, 2008 | 01:23 AM
  #22
TouchOfEvil04's Avatar
But are you getting full boost now?
Old Mar 28, 2008 | 01:36 AM
  #23
La Riddler's Avatar
I retapped the boost line in other location and read 6psi. I'm going to have to reroute the vac lines to see if I get the other 2-3 psi.
Old Mar 28, 2008 | 01:43 AM
  #24
Q8 6.0's Avatar
OH very cool...
about boost loss im sure if you PM Magnacharger rep or Blown chevy they will go over it step by step .
i hope it is something simple but here is a small test you can try to see if you have boost leak..... the top part of the charger (rotor housing) is held to the lower part (intercooler housing) by 6 bolts 3 on each side there is a very small chance the bolts backed out creating boost leak at high rpm..
easy way to make sure is turn off truck remove belt put both hands on the top of the charger and shake it from side to side if you have any play then there is your boost leak..
Old Mar 28, 2008 | 01:49 AM
  #25
Q8 6.0's Avatar
no this will not get you more boost its only to make the radix quieter to keep you and the knock sensors happy
Old Mar 28, 2008 | 02:00 AM
  #26
La Riddler's Avatar
Thanks once again for helping out. I'll definetly look into that. I'm glad to see boost increase on the gauge and no more knocking. It sounded like if the motor was taking a dump.
Slow94Formula
Nov 15, 2015 09:23 PM
bagged7104SS
Sep 24, 2015 08:42 PM
DrX
Sep 18, 2015 08:53 AM
SWINGRRRR
Sep 1, 2015 05:25 PM
DrX
Aug 19, 2015 04:45 PM
