When would you refresh your Radix?
Old Mar 23, 2008 | 04:46 PM
Neverdone's Avatar
Default When would you refresh your Radix?
Wondering when you would want to refresh your blower? Assuming you don't overdrive and you are stock, is 20,000 mi on the high side or will I have nothing to worry about for a long time?
Old Mar 23, 2008 | 04:58 PM
kbracing96's Avatar
My roommate had 80k+ on his when he sent it in for a refresh. Was still running strong and had been pullied down for a long time.
Old Mar 23, 2008 | 05:00 PM
Neverdone's Avatar
I should also ask what a refresh is worth? Just trying to cover all my bases
Old Mar 23, 2008 | 05:09 PM
CashDudeHomie's Avatar
There's a deal where they will upgrade you to the 122 for a pretty cheap price.
Old Mar 23, 2008 | 05:18 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would not worry about it until you reach 75-80K on the ticker. I have seen them go 100K+.
Old Mar 23, 2008 | 05:44 PM
Neverdone's Avatar
Appreciate the info, thanks!
Old Mar 23, 2008 | 09:02 PM
fish5225's Avatar
I'm at 78k with no problems. Change the oil in the nose at 40k and you should be good to go.
Old Mar 23, 2008 | 09:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
The oil is good for more than that
Old Mar 23, 2008 | 09:26 PM
La Riddler's Avatar
I have some play on the pulley like a 1/4 back and forth. Is there a kit to fix this or is it normal. It has about 15k mi on it.
Old Mar 23, 2008 | 09:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
The nose has a torsional isolator in it. Play back and forth is the spring loaded connection between the nose drive and the rotors.
Perfectly normal.
