Whats it worth F1A procharged yukon
93dr yukon 4x4 body is rust free interior needs some work
383 Eagle Crank and Hbeam rods ARP rod bolts and main studs (4bolt)
Diamond forged pistons AFR 180 heads
Roller cam
Comp Roller Rockers 1.6
F1A Procharger 4.75 pulley
Procharger 12 rib setup
Have bracket if you want to run AC
Accell Gen7 DFI/w Wideband custom harness
Accel Proram system with 60LB injectors 1040 CFR throttle body
Viligalate multi disk 2800 stall
TCI trans controller
4l60 trans
Snow Performance Meth kit Stage 2
Aeromotive Sump kit A1000 pump -10 feed -8 return
4:10 front and rear with eaton possi
Driving it everyday 80+ miles to work and back
going a different direction right now
looking at asking 8k for everything am I way off base ?
Roller cam
4l60 trans
calsdad
Jun 14, 2023 11:07 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
