Whats it worth F1A procharged yukon
Old Mar 16, 2011 | 01:34 PM
the_reaper's Avatar
Default Whats it worth F1A procharged yukon
93dr yukon 4x4 body is rust free interior needs some work
383 Eagle Crank and Hbeam rods ARP rod bolts and main studs (4bolt)
Diamond forged pistons AFR 180 heads
Roller cam
Comp Roller Rockers 1.6
F1A Procharger 4.75 pulley
Procharger 12 rib setup
Have bracket if you want to run AC
Accell Gen7 DFI/w Wideband custom harness
Accel Proram system with 60LB injectors 1040 CFR throttle body
Viligalate multi disk 2800 stall
TCI trans controller
4l60 trans
Snow Performance Meth kit Stage 2
Aeromotive Sump kit A1000 pump -10 feed -8 return
4:10 front and rear with eaton possi
Driving it everyday 80+ miles to work and back
going a different direction right now
looking at asking 8k for everything am I way off base ?
Old Mar 16, 2011 | 02:07 PM
TX Tahoe Z71's Avatar
You're better off parting it out. Not that your truck isn't sweet, but you might have a hard time getting $4k for it, depending on condition, as it is 18 years old.
Old Mar 16, 2011 | 03:17 PM
ig109's Avatar
Yeah, pull the engine and sell it then cram a JY engine in it and sell the YUKON...
Been there done that and it is sad but true..
calsdad
Jun 14, 2023 11:07 PM
madmann26
Apr 29, 2020 09:17 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
murderedSS
Sep 27, 2015 10:16 PM
MOBBN
Sep 22, 2015 08:07 PM
