Whats the best size blower for a 434? 2.8 or 3.6 KB?
#51
#52
did you get your blower through TPE?
i'm looking at getting one for my C5 vette
ps - and don't trust interweb specs for your weight. friggin Uhaul thinks my 4x4 RCSB NBS is only 4200lb
#55
Truck looks great! That's the setup I wanted to go with but chickened out when I cooldn't get anyone at KB to even talk to me about using it on a truck. The only thing I see missing is the oversized composite intercooler tank from Trick. Which HX are you using and how did it mount up?
Hutter Performance mounted the intercooler in the lower grill of my bumper where I had my old A2A intercooler.
The car wash already messed up the fins of the cooler but I found a radiator comb from JEGS that should straighten everything out.
Im not familar with his setup. What type of tensioner is he running? Any pics? I am having a little bit of belt slip so far. I'm hoping that changing over to a Gates belt will solve the issue but if not I might need something else.
#56
If your interested I can help you put everything together to bolt the 3.6L on. Pm me for more info.
I got everything from Hutter Performance. I'd give them a call corvettes are their specialty and I'm sure they could help put something nasty together for your C5.
Thanks, I think it really came out great as well.
Ya the block definitely added some weight up front. Your probably right about my truck weighing 6k plus. It sure doesn't feel like theres that much weight when I hit the pedal though. I'll get it weighed this summer to find out for sure.
The drivetrain loss from my 4l85 really eats up some HP. Hutter Performance had a stock ZR1 on their dyno last month that put down 516whp. So if you figure the vette's engine were in front of my transmission it would only put down somewhere around 465whp due to my transmissions extra 10% drivetrain loss. Its hard to compare the two but I think the extra CI on my setup is helping a little bit. My heads are pretty much stock L92's with some valve work and a mild cam.
Heres the ZR1 on the dyno.
I love that setup! Yeah my Silverado, stone stock, would have been at 54xx pounds; with the tires I'd call it 5550 or so. With the beefier iron block you added about 200lbs plus a blower, so you have to be jumping around the 6k mark. It isn't going to make too much of a difference anyway with that ~650-horse monster under the hood
Yeah I was thinking about the extra drivetrain loss and the lower bost, but the I figured the extra 58ci would make up for that. I completely forgot about how conservative your camshaft might be. Sounds like it will be a very nice combo for you
#57
#58
#59
Lol sorry about that, but ya I'm more familiar with BMW engines. Hutter Performance is also building my M3's motor for a turbo setup and sometimes I mix things up since that engine runs dual overhead cams.
#60
