Whats the best size blower for a 434? 2.8 or 3.6 KB?
Old Mar 19, 2011 | 08:02 AM
  #41
OnyxSilveradoSS's Avatar
what atomic said. but I could bet you are breaking it in slow and will turn the boost up to 18psi
Old Mar 19, 2011 | 11:48 AM
  #42
There comes a point when the TB and intake piping will be the restriction. I dont expect that to happen until he is in the 700HP range. Have fun dialing it in. From all the data available, the 102mm should get him min 45-50hp.
Old Mar 20, 2011 | 01:23 PM
  #43
Bromaguire's Avatar
Originally Posted by Midnight
Can you post some more pics of that intake inlet?
I'll post some more pictures up in a just little bit.
Originally Posted by Atomic
Dont take this the wrong way but isnt 500hp with 8lbs on a 434 a rather low number?
I would agree 505whp at 8lbs was a low number but that was just getting things started with a conservative tune only running the engine to 5900 rpm. They've already got the combo making 535whp just running it up to 6500 rpm's. Im running out of fuel pressure so once thats taken care of we will push it a little more. The motor is made to run at 7000 rpms. I had this combo put together to be daily driver friendly and still be able to tow my boat without any problems around the launch ramps, so the cams aren't very extreme either.
I'll post the dyno up of the latest run.
Originally Posted by rjwz28
I'm inclined to agree: that's close to the numbers from a stock ZR1, which does seem a bit low considering that this truck has a larger engine and bigger blower. Is the truck AWD or 2WD? That makes a big difference.
The zr1 is running a bit more boost than I am at this point and is also putting the power down through a manual transmission with less drivetrain loss. I am lossing around 30% which I confirmed by running my old engine combo on an engine dyno after it was removed.
My Denali was dynoed in 2wd.
Old Mar 20, 2011 | 01:53 PM
  #44
2004SSS's Avatar
there is alot more in that setup for sure. im surprised you got it to work with the tb and alt on the same side and made it look good. imo the belt drive needs some love , are you experiencing any belt slip as of now??
that is the 3.6 blower correct?
BTW i bet your denali weighs more than 5500lbs , my truck weighs 6k+ .
Old Mar 20, 2011 | 02:10 PM
  #45
Bromaguire's Avatar
Thanks. The pulley I have is actually machined to be a bit different than the standard Kenne Bell to help the belt from coming off the pulley. Its slips a little up top but not enough that I'm concered. I think a different brand belt would solve the slipping I'm having now.
The blower is the 3.6
Your probably right about the weight. I just pulled that spec from one I found on the net, I've never had it weighed.
Heres a few more pictures.
This picture shows how small my current throttle body is compared to the blower inlet.
Old Mar 20, 2011 | 08:52 PM
  #46
rjwz28's Avatar
Man Motor club
I love that setup! Yeah my Silverado, stone stock, would have been at 54xx pounds; with the tires I'd call it 5550 or so. With the beefier iron block you added about 200lbs plus a blower, so you have to be jumping around the 6k mark. It isn't going to make too much of a difference anyway with that ~650-horse monster under the hood
Yeah I was thinking about the extra drivetrain loss and the lower bost, but the I figured the extra 58ci would make up for that. I completely forgot about how conservative your camshaft might be. Sounds like it will be a very nice combo for you
Old Mar 21, 2011 | 09:23 AM
  #47
mammoth with that TB looks funny
I would guess more gain from it...those blowers are sick when you start to open up the inlet side. And you have the best elbow, just need to match the TB. cool
Old Mar 22, 2011 | 10:05 AM
  #48
Lucille's Avatar
Truck looks great! That's the setup I wanted to go with but chickened out when I cooldn't get anyone at KB to even talk to me about using it on a truck. The only thing I see missing is the oversized composite intercooler tank from Trick. Which HX are you using and how did it mount up?
Old Mar 22, 2011 | 01:12 PM
  #49
BigKID's Avatar
Nice work on the intake. With the Mammoth inlet, smaller TB with offset adapter, you actually have more clearance to the alternator than I have with the 2.8 inlet and 95mm TB.
Old Mar 23, 2011 | 01:07 AM
  #50
2004SSS's Avatar
if you can get one of the hd tensioners on there that will help a ton. joe with the tbss can probably set you up with one , it may take some minor mods to make it work but it will make a world of a difference .
