What would need to be changed??
Old Aug 9, 2009 | 11:14 PM
Bluchevypick's Avatar
Default What would need to be changed??
I am thinking about going with a radix on my truck. I know the usual stuff like udp and what not has to be changed but would I be ok with my head package? I know it would work better with a different cam also. And what would I expect as far as gains go?
Old Aug 10, 2009 | 12:17 PM
No opinions???
Old Aug 10, 2009 | 12:42 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Heads and cam look good, you can always swap cams later. UDP has to go, as you mentioned. Your heads/exhaust will work very well with the SC, your measured Boost will be lower but you'll make better power due to the much improved exhausting.
DOIT!!
Old Aug 10, 2009 | 12:55 PM
How much boost could I run safely
Old Aug 10, 2009 | 01:29 PM
trever1t's Avatar
depends on your tuning capabilities. I ran 11lbs with the 112 on my 5.3L with methanol injection. General opinion is 10lbs is about max safe with meth and spot-on tune. Startt slow and build up. With your heads and exhaust you will need a very small pulley, remember, Boost pressure is measured in the manifold after the valve event, it is a measure of wasted energy.
Old Aug 10, 2009 | 03:00 PM
I don't plan on running any meth at all. Not trying to push it just wanna make good power. What you think it will make overall on 7 lbs?
Old Aug 10, 2009 | 03:20 PM
sharpshooter's Avatar
changing to a lower stall,bigger injectors and fuel pump
Old Aug 10, 2009 | 03:28 PM
Plan on doin inline walbro but injectors should be alright seeing that I'm barely at 60% duty cycle right now and I'm not changing my stall again. Lol
Old Aug 10, 2009 | 10:09 PM
DrX's Avatar
DrX
Pin the crank pulley when you do the swap.
Old Aug 10, 2009 | 11:48 PM
zippy's Avatar
What is your compression?
