What weight oil for the boosted guys.??
Old Apr 24, 2009 | 01:59 AM
mike06tork's Avatar
Default What weight oil for the boosted guys.??
What weight engine oil are you boosted guys running. This is a daily driver....
Turbo guys post up what oil are you rnning? well after my engine warms up my oil looks like water. it gets so thin i think its 10-30 what i have... motor has 950 miles 370ci. 8.8compression, PT88mm turbo. running stock oil pump
oil pressure cold start 43-45psi idle
warm oil after a few minutes engine running from a cold start, 38-40 psi idle
engine hot after a cople of pulls, oil press. around 30-32psi at idle with oil so thin like water - engine hot so hot as hell oil.
will this one work good 15w40 rotella oil or 20W50 oil.......
Thanks
Old Apr 24, 2009 | 02:13 AM
thunder550's Avatar
High on diesel fumes
Depends on what your clearances were set up for. I was running M1 15-50 per Rex's instructions. Thicker oil for looser engines.
Old Apr 24, 2009 | 11:43 AM
silveradol33's Avatar
15/40 Rotella
Old Apr 24, 2009 | 01:00 PM
silver-mod-o's Avatar
Hunt&Fisherator
15/50 in my turbo'd 347... built loose as well. been running Mobil 1, but I'm gonna go to Valvoline VR-1 this time around.
Old Apr 24, 2009 | 01:06 PM
WJ MARK's Avatar
0-30 or 5-30
Old Apr 24, 2009 | 02:09 PM
05crew's Avatar
just put the new 408 in, running 10-30 rotella for about 500 miles or so, built my motor loose also, and i was told to run 5-30 siy. M1. after the 500 miles is over
Old Apr 24, 2009 | 03:47 PM
KySilverado's Avatar
5-30 m1
Old Apr 25, 2009 | 08:29 PM
Coban's Avatar
15w40 or 0w40 in my turbo'd stock 5.3
Old Apr 25, 2009 | 09:14 PM
03sierraslt's Avatar
5w30 Penz Plat.
Old Apr 25, 2009 | 09:24 PM
Wilde Racing's Avatar
How do I change this text
The turbo doesnt give a crap, it's the bearing clearance that cares..... I run 5-30 in mine due to the near stock bearing clearance... they seam to be happy.....
