What weight oil for the boosted guys.??
What weight engine oil are you boosted guys running. This is a daily driver....
Turbo guys post up what oil are you rnning? well after my engine warms up my oil looks like water. it gets so thin i think its 10-30 what i have... motor has 950 miles 370ci. 8.8compression, PT88mm turbo. running stock oil pump
oil pressure cold start 43-45psi idle
warm oil after a few minutes engine running from a cold start, 38-40 psi idle
engine hot after a cople of pulls, oil press. around 30-32psi at idle with oil so thin like water - engine hot so hot as hell oil.
will this one work good 15w40 rotella oil or 20W50 oil.......
Thanks
Thanks
