what are the smallest gears and stall for procharger
Old Mar 23, 2012 | 08:54 AM
lablackbeast's Avatar
doesn't know what quit means
Default what are the smallest gears and stall for procharger
was up guys, havent asked questions lately but i wanted to know what will be the smallest gears or stall i can run on a procharger set up, i want a street beast and i am trying to get as much mph as i can, and i heard with the smaller the gear the higher mph ill get but then again i want a gear that will stay on the power band and not go all the way down, right now it has 410 gears, and a 4200 stall it pushed 761rwhp thru that and a 4l80 on a 6.0 with the F1a and 16psi, now its gonna be a 6.2 forged, ported heads, custom grind cam, the smallest gears i can get, the smallest stall i can get to my benifit, and e85 o and also 4.0 pulley to the 4.5 it had when it made 16psi, i want to be up there in the mph, lmk what should i do thanks in advance
Old Mar 23, 2012 | 12:01 PM
1989k1500's Avatar
Put whatever gear you need for the mph you want. And lock the converter.
Old Mar 23, 2012 | 12:23 PM
03regcab sierra's Avatar
There should be a gear calculater on here somewhere but I imagine the 4.10s should be pretty close to wat u need. Depending on how high u rev your motor and how tall your tires are.
Old Mar 24, 2012 | 02:45 AM
slowlsx's Avatar
3.42's 3600 stall and lock up the converter at WOT.
Old Mar 24, 2012 | 02:50 AM
AndysC3's Avatar
Im currently using 4.56 and a 3600-3700 rpm torque converter. I may end up going to 4.10s once I drop my truck and go with a smaller tire.
Old Mar 25, 2012 | 12:33 PM
you think itll still work with the procharger.? since they say prochargers love loose stall and big gears
Old Mar 25, 2012 | 09:25 PM
slowlsx's Avatar
well you want the mph for the street or for the track? with those 20's i dont see how your going to do anything with all that power. if i were you i would leave it exactly the way it is, log your passes and see what RPM you go thru the traps at and how much if any your converter is slipping and then adjust your converter and gears with the data you get.
Old Mar 26, 2012 | 12:16 PM
your willing to help me out with that.? i mean with the old set up before i would cross the traps it would "sound" like it was running out of gear, but if the stall will lock up at 100 it wouldnt run out of gear, and i really want the MPH for the street
Old Mar 29, 2012 | 09:27 AM
bump, for a street machine!!
LCHEE
Oct 24, 2020 04:10 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
fcompean
Jul 15, 2015 09:55 PM
06 4.8
Jul 14, 2015 08:09 AM
