What size turbo for rear midmount DIY 5-6pis
Old Mar 29, 2013 | 01:44 AM
2ktransam's Avatar
Originally Posted by 2000chevysilverado
What size oil lines did ya use??
I use a 4an feed with a restrictor. If you guys are making a rear mount setup, make sure you put a check valve on your feed line. If you don't, oil will puddle in the turbo while the engine is off and push through the turbo seals. I got my check valve from sts.
Old Mar 29, 2013 | 12:38 PM
Camin00's Avatar
Originally Posted by 2ktransam
I had a gt67 on a sts kit in my Firebird a long time ago. It made 505rwhp on 6psi and spooled really quick. T70 or gt67 would be my vote.
wowzers sold on the gt67 haha
What are some good reliable budget brands for waste gates and blow off valves
Old Mar 29, 2013 | 12:53 PM
gamble686's Avatar
If you are only looking for 100extra and want to keep the long tubes why not pick up a second hand supercharger? Much much easier and will deliver no problem.
Old Mar 29, 2013 | 02:34 PM
Camin00's Avatar
I love the turbo sound
Old Mar 29, 2013 | 02:36 PM
2000chevysilverado's Avatar
Dont forget the duck call as well for bov
Old Mar 29, 2013 | 02:50 PM
nonnieselman's Avatar
duck call is more of a not working too good BOV.. and surges the compressor
But i had the Garrett 60mm with a .86? turbine housing.
here is from my dyno post back in 2009..
bone stock LQ4 thru a 4L80E in 2nd with the converter locked on a Dyno Dynamics stingy dyno
44# injectors and a Walbro 255. Turbo was maxed out.. look at the torque falling off fast.
Lots of torque down low tho.
Your not goin to get boost at 1600 from off idle, more like 3000rpms.. but cruising with the converter locked you can get boost down low around 1800ish.
6#
8#
6# + 50 shot
TAPyvehc93
Jul 23, 2017 10:54 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
