What size is this turbo?
Nobody has any insight on holset turbos?
I have a buddy that aborted his fox body turbo project, has this freshly rebuilt HX-50 holset, three J-bends,and three V-band clamps. He will sell the "sloppy turbo starter kit" for $300. Is this a worthwhile deal?
I would like to put this on a 5.3, flipped manifold, non-intercooled, meth injected setup.
Is this turbo remotely sized "properly" for a 5.3?
Little more info...
Our Turbos -
"With HX50 compressor wheel (64mm inducer, 93mm exducer) and HX50 turbine wheels (86mm inducer, 72mm exducer),"
Our Turbos -
So that map is all crazy with the x & y access. I mapped a borg warner s300 with a similar size compressor and turbine.
Looks like it'll run out of air around 5500 rpm. I was pretty conservative with the VE. If the VE is higher it'll run out sooner.
Stainless Works
13
Nov 5, 2015 03:31 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
GMCtrk
Jul 17, 2015 06:39 PM
