What size pulley is this?
Old Sep 11, 2005 | 10:31 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default What size pulley is this?
How do I tell what size pulley this is? I got a couple of extras when I bought the kit. Seller said one was a 2.75 and the other was a 3.25. I have the 3.4 on the Radix now. How do I measure the pulley to see which one I have because the other is missing in my garage, fat chance of finding it. Check out my pics and take your best guess. Measures from outside to outside on center at 3 1/8 inch. Thanks, Chris
Old Sep 11, 2005 | 10:39 PM
mjgjr72's Avatar
looks like 3.25
Old Sep 12, 2005 | 06:42 PM
1SlowHoe's Avatar
What would be the inside measurements of a 3.2" pulley? If I wrap a piece of paper around the inside of the pulley (as if it were the belt) to wrap all the way around is exactly 9 1/4". I found the other pulley, its wrap around measures 8 3/4" so I just want to make sure they are 3.2 and 2.75. I also have a 3.7 that is marked. What uses that one, the 4.8L?
Old Sep 12, 2005 | 06:54 PM
CHarris's Avatar
The 3.7 is what you swap to when you valet park or give the keys to a relative
Old Sep 12, 2005 | 06:57 PM
1SlowHoe's Avatar
LMAO...Or when you take it to the tranny shop for warranty work.
Old Sep 12, 2005 | 08:36 PM
mjgjr72's Avatar
diameter x pi (3.14) = circumfrance
aproximate
3.7 = 11.6
3.2 = 10
3.0 = 9.4
2.75 = 8.6
Old Sep 12, 2005 | 08:40 PM
TurboGibbs's Avatar
Old Sep 12, 2005 | 08:43 PM
1SlowHoe's Avatar
aproximate
3.7 = 11.6
3.2 = 10
3.0 = 9.4
2.75 = 8.6
There’s a reason I’m one class short of my Bachelors degree. It’s called Pre-Calculus Algebra, and I don’t do it. You’ll have to explain further ‘cause my measurements don’t equal your pi equation.
Old Sep 12, 2005 | 08:56 PM
1SlowHoe's Avatar
3.7" pulley measures in at 11 3/4" so...11.75 / 3.14 =3.7420382......
so my 8.75 pulley should be a 2.78 and my 9.25 pulley should be a 2.94 which would be rounded to be a 3.0? Hell I give up?
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
