what is better
Old Sep 12, 2005 | 08:15 AM
PEDRO's Avatar
12 Second SUV Club
Default what is better
supercharger or turbo for better numbers at the 1/4 ????
Old Sep 12, 2005 | 09:12 AM
Last Call's Avatar
TOTM: January 2007
There are a lot of variables here. I would have to say the turbo will net you the best ET at the track.
My consideration would be between the Livernois turbo and the radix.
Old Sep 12, 2005 | 10:37 AM
8ALTNG's Avatar
What no love for the STS kit?????? I have yet to see someone be dissapointed by this kit. It added about 100rwhp and over 100rwt over what my radix did.
Old Sep 12, 2005 | 10:44 AM
14 Second Truck Club
I would say turbo, and I have a supercharger.
Old Sep 12, 2005 | 10:54 AM
vanillagorilla's Avatar
This is going to get ugly. Keep it clean gentlemen.
My opinion is that is a loaded question. Too many variables. Be more specific. Are we talking a Radix or a centrifi? Are both trucks identical, because each truck will like a different stall based off of the type of FI. Plus different bolt ons will have different effects as well. What about cams?
Old Sep 12, 2005 | 05:05 PM
PEDRO's Avatar
12 Second SUV Club
ok on a 4.8 scsb 2005 automatic with no bolt ons yet o its a silverado
Old Sep 12, 2005 | 05:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
any time you can deliver power to the ground all the way though the power band, the better the et will be.
6 psi of Turbo/centrifugal against 6 psi of Radix......On the dyno and the track, I would put my money on the Radix.
Old Sep 12, 2005 | 05:34 PM
Totally stock truck...I'd say the Radix. The centrifi and turbo would most likely need a stall to compete. There's other factors though, like elevation and a properly sized turbo. Not much has been seen for the Livernois kit, but I'd bet it'd be close. I know here, turbo's tend to perform better than superchargers. They're not as affected by the high DA's we get here.
A better question might be which one would net the best mph. That's a function of the overall power. The ET mostly comes from traction and chassis setup.
Old Sep 12, 2005 | 05:54 PM
leftcoast32's Avatar
FormerVendor
I have seen some wild "Radix Supercharged" vehicles (2002 Z06) around here before Carlsbad closed down. I will have to travel to find a new track now.
Turbo will have less parasitic loss. Regardless of what the loss is at cruising speed, under boost superchargers use more power. A properly sized turbo on similar boost as a radix or centrifugal will be faster. If the turbo is too large and spool time is long, that is a different story. Just talking 1/4 mile times like you asked, you are only in the low end for a short time and as long as the turbo is sized right you should be good on the low end. Even my D1 would build around 2 psi with a TB stall, I would imagine a small to mid sized turbo would do better.
