What posi big power guys using that wont break?
Old Apr 16, 2019 | 12:34 PM
terravast4's Avatar
Originally Posted by fastjweb
Had the same tru trac for 5 years now, 16s to 9s, 1.41 60fts. I have replaced gears once in that time and broke a stock axle recently because i tried to make 18lbs off boost on foot brake, hydroboost held it, something had to give. The last time swapped gears, i did solid pinion shim, and added studs to bearing caps, and I have the B&M girdle cover.
what axles are you running?
Old Apr 16, 2019 | 01:02 PM
fastjweb's Avatar
I got Moser in it now. I have to be honest though, I don't think the stock would have broken with turbo. I usually left at 6-8lbs and cut 1.4-1.5s off foot brake, when it broke it wasn't on launch, it was 18lbs and 3800 rpm up against the brakes.
Old Apr 17, 2019 | 01:11 PM
terravast4's Avatar
those stockers held some power for a while then. I would rather be proactive though
Old Apr 18, 2019 | 08:47 AM
fastjweb's Avatar
They did for sure, they just couldn't take a 18lbs brake hold. I ran slicks a lot too so that probably put less stress on them than a radial too.
Old Apr 18, 2019 | 09:30 AM
MikeGyver's Avatar
For my education, why might slicks put less strain on the drivetrain than radials would?
Old Apr 18, 2019 | 09:46 AM
fastjweb's Avatar
slicks do not dead hook, controlled spin, so I feel would put less shock on the axles. A radial is designed to dead hook.
Old Apr 18, 2019 | 12:07 PM
terravast4's Avatar
I thought it was the opposite. I always thought slicks break **** cause they hook better.
Old Apr 18, 2019 | 01:08 PM
fastjweb's Avatar
[QUOTE=terravast4;5461208]I thought it was the opposite. I always thought slicks break **** cause they hook better.[/QUOTE
for sure more strain than a street tire, from what I know the slicks will absorb a lot of energy and have controlled spin to them. To make a radial hook, it needs to pretty much dead hook which I feel would shock the system more. a hard nitrous hit off the line would be worse to me than turbo, or manual car dumping the clutch would be harder on things than a stalled auto. I was leaving off foot brake and 6-8lbs on slicks so I was just saying from my own views the axles would have been fine.
Z71/99
May 24, 2008 10:43 AM
2004SSS
Aug 10, 2007 07:34 PM
BigKID
Oct 30, 2005 01:43 PM
MacADaYear
May 16, 2004 02:08 PM
