What peak boost number
Old Sep 2, 2009 | 08:35 PM
bleedchevy's Avatar
Default What peak boost number
How high of a boost number should i be seeing when on a tvs 1900? When i get on the gas it shoots to 13 then back down to 2 to 3 at 25 to 30 mph.
Old Sep 2, 2009 | 08:42 PM
viciousknid's Avatar
Where's the Beef?
How much do you know about Forced Induction?
How much boost you make not only depends on your mods but also the size of they pulley.
Old Sep 2, 2009 | 08:52 PM
bleedchevy's Avatar
I'm all stock, i know that it will not stay in boost at cruising speeds if anything i will likely see little. i was just wondering how high of a peak would i expect at wot, again im all stock, for now anyway.
Old Sep 2, 2009 | 09:16 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
a stock 6L with stock TVS R1900 will make peak ~6lbs. As you let off the throttle you will go "out of boost" completely.
Old Sep 2, 2009 | 09:21 PM
BigCountryx's Avatar
do you have an electric boost gauge? I've got full exhaust with no cats, but the supplied 3.4" pulley gave me 4.5lbs, a 3.1" gave me 6lbs and the 3.0" has me at 7lbs and it never surges like you described.
Old Sep 2, 2009 | 09:25 PM
old motorhead's Avatar
Whew????
Old Sep 3, 2009 | 10:12 PM
MarineBlue03GMC's Avatar
Tech Fanatic
Definitely something going on since your boost should not be surging like that. I'd check the boost gauge/vacuum lines.
Old Sep 4, 2009 | 08:41 PM
bleedchevy's Avatar
well what im trying to get at is how much boost should i expect or should be seeing at wot, i thought it was limited to 6lbs, but i have been hitting higher numbers, i looked for leaks didnt find any.
Old Sep 4, 2009 | 08:59 PM
MikeGyver's Avatar
Do you have a tuning program? If you could post a scan of what you are talking about, that would be very helpful.
Old Sep 4, 2009 | 09:31 PM
Tech Fanatic
My TVS1900 has the 3.0" pulley and consistently boosts 7psi at WOT. If you have the standard kit pulley then I don't think you should ever be seeing anything over 6psi.
