what are the limits of a single intake walbro??
Old Nov 1, 2008 | 07:13 PM
Default what are the limits of a single in-tank walbro??
i think i just maxed out my pump so now i need to figure out the next step or if i did not, need to find out what is wrong.
here is the set-up
6.0L 225/225 @ 113 .581"/.581" pt70gts turbo livernois kit full straight through 3" exhaust 8psi boost
we finally had a chance to get it on the dyno and at about 4500rpm the fuel pressure dropped quite a bit quickly to 40 psi and we shut it down. i have only a single 255 walbro in the tank with still the returnless set-up.
i am doing a return style setup now but woundering if when im there, do a second in-tank. i want to make sure i wont have any problems latter.
Old Nov 1, 2008 | 07:27 PM
EDawg's Avatar
here is the set-up
i would do a second. i never drop below 65 psi and im running 13 pounds
Old Nov 1, 2008 | 07:37 PM
yea, hard to say, did this pump fail or did it just run out of steam???
when i drop the tank should i just add one or replace the 2
it is only 3000 miles old
would you wire in both pumps to run at the same time or wire in one to switch on at a certain boost level??
Old Nov 1, 2008 | 07:40 PM
EDawg's Avatar
allan did mine. they both run at the same time. the rest is in the tune.
i had a buddy that had a pump fail with less than 100 miles
Old Nov 1, 2008 | 07:46 PM
is he feeding them both off the factory harness??
Old Nov 1, 2008 | 07:49 PM
EDawg's Avatar
yup. theres a post on here somewhere on how to do it with pics
Old Nov 1, 2008 | 07:58 PM
setting it up is easy but just woundering if the harness can handle the draw but it looks like it works
Old Nov 1, 2008 | 08:01 PM
EDawg's Avatar
have never had a problem. from what i have seen....its done all the time. you should be just fine.
Old Nov 1, 2008 | 08:13 PM
good deal, im going to do the easy return line off the sheader valve with the 2 in-tanks
Old Nov 2, 2008 | 07:18 AM
Raffman's Avatar
I would add more power, a relay & 10 ga wire. The pump is nothing more than an electric motor and low voltage will keep any elec motor from peak performance and eventually kill it.
