What is the limitation of the stock Fuel Pump?
Old Sep 26, 2005 | 10:13 AM
TG02Z71's Avatar
Default What is the limitation of the stock Fuel Pump?
So what can the stock fuel pump support?
I know it depends on what type of boost you are running (Turbo/Blower).
And how much maximum PSI you run.
I'm just trying to get an idea of where my cutoff point is for my set-up.
I don't think I'll run any more than 10 psi when I go to the track, but I still want to be safe at that level of boost.
Old Sep 26, 2005 | 10:25 AM
BlownChevy's Avatar
blownerator
25 Year Member
350 rwhp.
Old Sep 26, 2005 | 11:13 AM
vanillagorilla's Avatar
You can't go by boost levels. Because a 6.0L would probably make more power than a 4.8L at the same boost level.
I see you have 44lb'ers so you'll be good to go there.
Old Sep 26, 2005 | 09:13 PM
quicksilverado's Avatar
Don't risk it. Get a fuel pump and play it safe.
Old Sep 26, 2005 | 09:32 PM
parish8's Avatar
single digit dreamer
i always thought it was over 400rwhp. i have sprayed a 150shot on a 6.0 and was ok but when i tried the 175shot the fp started to drop up top.
Old Sep 27, 2005 | 06:13 AM
TG02Z71's Avatar
So basically I'm so borderline right now it would be a risk for my current set-up? I have heard things pro and con for the in-line pump, what opinions do you guys have on the subject of in tank or in line pumps?
Thanks for the feedback.
Tim
Old Sep 27, 2005 | 06:32 AM
parish8's Avatar
i had an inline pump on my last truck and it seems to work great. before i got rid of the truck i was up to 10psi and a 100shot on a 6.0. they are cheap too.
Old Sep 27, 2005 | 06:33 AM
JERRY2500's Avatar
14 Second Truck Club
Get the fuel pump, I was going lean 2 8psi
5.3Okasai
Mar 9, 2022 01:07 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
lxcoupe
Jul 21, 2015 02:12 AM
76k10chase
Jul 17, 2015 01:48 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
