what headgaskets for turbo lq4
Old Feb 10, 2011 | 07:30 PM
rhinosarge's Avatar
Originally Posted by denali_on_26's
ls9 gaskets and arp studs
Just do it right the first time
so stud kit .. u got the part # where to order?
Old Feb 10, 2011 | 07:32 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Got mine from summit and gaskets from gm
Old Feb 10, 2011 | 07:33 PM
rhinosarge's Avatar
i ordered the gaskets from the one website above.. im going on summit right now.. i know theyre gonna be pricey
Old Feb 10, 2011 | 07:38 PM
But you only have to buy them once
Old Feb 10, 2011 | 07:39 PM
rhinosarge's Avatar
http://www.summitracing.com/parts/ARP-234-5608/
look about right?
Old Feb 10, 2011 | 09:16 PM
schino's Avatar
Originally Posted by rhinosarge
Your link is to main studs for the crank/caps. Iirc there are 3 maybe 4 different arp studs for the heads. Unequal length for older motors, all same lgth for newer, not sure of year cut off, and also the 6 bolts which you won't need without an aftermarket 6 bolt block.
Old Feb 10, 2011 | 09:59 PM
foose04's Avatar
I run ls9 gaskets and ARP's on mine. I've ran alot of 15-17psi runs, one at 20-21 and haven't pushed a drop. Stock gaskets and stock bolts made it till about 17-18psi and started to push. Ow, and this is on a little 4.8L (617HP at 15psi)
Old Feb 10, 2011 | 10:19 PM
Rick_Vor's Avatar
oh for sure then.. im staying at 8lb spring.. i really dont plan on going anymore since ill be on the dessert all day.. and street. thanks
At 8lbs, ARP head studs are an unnecessary luxury. People run 10-12lbs all day long on OEM head bolts without a hitch. At about $60 per set, you'll have to change them over 4 times before you break even on what ARP's cost.
IF you are planning to run high $$$ heads down the road, build a forged motor and/or run on the ragged edge with timing/fuel, then ARP's would be a prudent purchase.
That said, I bought ARP's studs for my last build so I can have the option of turning up the boost down the road. What year is your donor block? 1999-early 2004 blocks require the ARP #234-4316 (long) stud kit. Late 2004-2006blocks require the ARP# 234-4317 (short) stud kit.
Rick
Old Feb 11, 2011 | 01:12 AM
guero68's Avatar
Rick
x2 for rick
yeah i put OEM bolts in mine 10lbs....just because at this point i am not looking at having a race motor that I would need to drop alot more money $$$ than i already have. 10lbs DD OEM will work with the OEM MLS gasket.
Unless you have a hard on for ARP you dont need them.
Old Feb 11, 2011 | 06:05 PM
rhinosarge's Avatar
Originally Posted by guero68
x2 for rick
haha thanks guys.. this motor i dont want to push anywhere over 8lbs.. why?? because ima be on the sand .. prerunning all the time.. thats all i need as far as boost on this block.
this block is from a 2000-02 lq4
i guess i will be buying some stock head bolts for now...
dealer?
5.3Okasai
Mar 9, 2022 01:07 PM
Blue03sss
Mar 7, 2019 05:06 PM
lxcoupe
Aug 26, 2015 07:24 PM
Cowboy17
Jul 9, 2015 08:22 PM
NuckenFuts
Jul 9, 2015 08:45 AM
