Help finding a belt.
Old Feb 10, 2011 | 09:07 AM
TrickTurbo's Avatar
Truck Sponsor
Default Help finding a belt.
I am have been searching for a 117-118.5 inch long 10 rib belt. Not having much luck. 8 rib stuff the local store has 10 rib seems to be a bit odd.. :
Looked on Gates site no luck.
If I can't find the 10 rib to the correct length, I have a couple of options.
1) go to an 8 rib.
2) redesign the belt wrap, and drive the altenator differently.
Old Feb 10, 2011 | 09:39 AM
BigKID's Avatar
I recently looked into belts when doing my research on 8 and 10 rib swaps and the longest belt I found in 10 rib was 111.5" and made by Gates. Neither Dayco, Bando nor Goodyear list any 10-rib belts over 100".
Old Feb 10, 2011 | 09:41 AM
TrickTurbo's Avatar
Truck Sponsor
Yea, thats what I have seeing. Looks like I will be going with an 8rib, unless I can figure something else out.
Did you happen to know of any cog MFG's?
Old Feb 10, 2011 | 09:52 AM
BigKID's Avatar
Sorry Rick, I wasn't specificly looking for cogs so I didn't pay a lot of attention to it. I know Dayco had a Top-Cog listed in their catalog but I think it was mostly small timing belts. For the length you are wanting in a cog, you may have to look into industrial belt manufacturers. Try Potomac Rubber and see if they have anything you can use.
Old Feb 10, 2011 | 11:00 AM
TrickTurbo's Avatar
Truck Sponsor
thanks, looks like I will go with the 8rib stuff for now. If I run into belt slip then deal with it..
Old Feb 11, 2011 | 10:14 AM
OnyxSilveradoSS's Avatar
double sixes??? I was looking at a ZR1 blower and thought that double six rib belts would be better than the expense of 10ribs stuff. or like you said drive the alternator with a seperate belt.
Old Feb 11, 2011 | 10:19 AM
2004SSS's Avatar
i know of a place i can have custom belts made price is pretty bad (200 or so each) but have recently gotten them to do better deals but its through a friend and he is a pita to deal with . he did make this though , he had to have a few of this legnth belt made and then have a few different power steering pulleies made to fit the belt best .
how many belts where you looking for? i can put you in contact with him and you can see what he says. pm me for info.
Old Feb 11, 2011 | 11:47 AM
SincalT/A's Avatar
Im not sure if they have what your lookin for but,I think Mcmaster Carr has serpntine belts in a handful of lengths and ribs.
Old Feb 11, 2011 | 02:14 PM
2toneblown's Avatar
LPE has one special made right around that length for their custom 2010 camaro 10 rib. Try giving them a ring
Old Feb 12, 2011 | 01:35 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by BlownChevy
K101098 is available
The belt number I posted up is one that WE had made for the 10 rib IFFD systems.
From Thread:
https://www.performancetrucks.net/fo...d.php?t=439218
Not sure if this helps, I just remembered reading it the other day.
I'd call Innovaters West. If they are selling 10 rib kits you'd think they would have a belt for R&D.
madmann26
Apr 29, 2020 09:17 AM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
shootermwc
Oct 8, 2015 01:45 PM
trxmxzx
Sep 29, 2015 07:42 AM
