What else do I need for my turbo setup
Old Oct 14, 2013 | 05:08 PM
BlackRCSB's Avatar
Default What else do I need for my turbo setup
Like most of y'all know I'm in the middle of starting my turbo build on my 03 silverado. It has a stock 4.8, as far as the kit, I have gt45 turbo, doing a log style setup so I have that figured out with crossover and all the hotside piping. I also have my intercooler and all the cold side mocked up. I have 52# injectors with pigtails and adapters. I have both bov and wg with a 4-5# spring
I also got the tune stuff settled out with hpt. I have efan setups also. I think this is all I need but idk. Would I need vacuum block even tho I'm not using a boost controller ? Tune will be SD so I have my iat sensor where it should be
Thanks for your comments
Old Oct 14, 2013 | 05:09 PM
BlackRCSB's Avatar
Also, is a oil catch can really necessary ?
Old Oct 14, 2013 | 05:16 PM
Ferocity02's Avatar
Fuel pump
You will need to figure out a PCV setup, catch can or breathers
Turbo oil feed and drain
Gauges
Old Oct 14, 2013 | 05:39 PM
BlackRCSB's Avatar
Forgot about the fuel pump lol I have that settled also lol, thinking of taping my timing chain cover for drain. And above oil filter for feed
Old Oct 14, 2013 | 05:42 PM
Chevy_King1500's Avatar
^ that would work, i run an upgraded PCV valve on mine, TB block off, passenger side cover has a breather
mhorn0817
Jul 8, 2017 01:54 AM
iregret
Jul 27, 2015 10:32 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
oharajo
Jul 18, 2015 09:24 PM
