Ok this the tube that you'll need to pull out. Then tap the hole and install an check valve in it. I also put an 90 deg fitting with it cuz oil will run down the bottom side of the intake and gets sucked into it.
Where can I find the correct check vavle and 90 degree fitting. I've been looking.
