What do I lack of being ready to INSTALL?? STS
Old Jan 17, 2009 | 04:42 PM
Ender06's Avatar
If i were you, i would lay everything out and try to make sure you have everything.. I had to install my STS 3 times because i would almost be thru and be missing a few peices. So i had to take it all off and wait till i got off work the next day to get the missing parts and start over.
Thats what I have been doing. I have my intercooler mounted, pipe from motor to intercooler done, next I plan on routing it back towards the rear.
Old Jan 29, 2009 | 10:15 PM
gmc6.0's Avatar
hows the build coming along
Old Jan 29, 2009 | 11:21 PM
Ender06's Avatar
Slowly, I really need to figure out how to tap vacuum from undeer the manifold
Old Jan 30, 2009 | 08:08 AM
gmc6.0's Avatar
you should of hit me up a week ago im selling my complete sts system..pm if your interested
Old Jan 30, 2009 | 06:57 PM
Whippled 496's Avatar
Is that an STS thing? Why not just "T" into the FPR vacuum line?
Old Jan 30, 2009 | 07:14 PM
TieRod's Avatar
If you don't install a check valve in this port you will pressurize the crank case under boost.
Whipped 496, if you did this on your truck. You may gain a pound of boost.
Sense I can't find my instructions. I'll take some picks of it tomorrow and post them.
Old Jan 30, 2009 | 07:45 PM
Ender06's Avatar
Thanks Man, I sent you a PM.
Old Feb 1, 2009 | 09:58 PM
TieRod's Avatar
Ok this the tube that you'll need to pull out. Then tap the hole and install an check valve in it. I also put an 90 deg fitting with it cuz oil will run down the bottom side of the intake and gets sucked into it.
This port will need to be blocked off. You can do this by making a new gasket for it and just don't make the hole for the port.
Old Feb 1, 2009 | 10:24 PM
Ender06's Avatar
Alright, thanks man, hopefully I can get this done this week. What exactly am I looking at in the first pic, is this under/inside the manifold? Or is it the head cover?
Old Feb 2, 2009 | 02:11 PM
TieRod's Avatar
Underside of the intake. As soon as you pull it you'll see it.
