What cracked these pitons?
13 Second Truck Club
Hey Guys...What do yall think cracked these pistons? Boost(pressure) or tuning(detonation)? These pistons are from a Nissan Titan with a MP112 and only 6psi. So far we know of 3 folks who have blown motors while using the S/C and not so many folks out there with Titans and a S/C kit. The top 2 are pics are from the same truck and the bottom 2 are from a different truck both using the MP112 with a Stillen piggyback that comes with the kit. The reason for my concern is I also have a S/C Titan which is making a bad tapping noise from the bottom of the motor, the same noise the vehicle in the top 2 pictures was making. The piece that broke off in the top 2 pics was trapped in between the piston rings and that’s what caused his tapping noise. I am the very 1st Titan owner to go against the grain and use larger injectors and a custom tuned ECU for more flexibility with tuning vs using the piggyback and the extra injectors. When my motor started tapping I was data logging religiously, my AFR was 12 flat and my timing peak was 25 degrees BTDC. I also did not notice any detonation when my motor started making this noise.
Originally Posted by Brian@JPA
Broken rings/ringlands are an indication of extreme cylinder pressures. Was the boost turned up? Tank of bad gas?
Originally Posted by NoRice
well if it didnt ping and you are running normal boost, then they are just weak *** pistons
Rex...........
