What cracked these pitons?
Old May 12, 2007 | 03:12 PM
  #21
moregrip's Avatar
what a rush!
Bummer bro, what's the new plan?
Old May 12, 2007 | 03:37 PM
  #22
BlownChevy's Avatar
blownerator
25 Year Member
Looks familiar, Detonation killed that piston and yours. The tuning on the Nissan leaves little to be desired IMHO.
Old May 12, 2007 | 07:33 PM
  #23
vanillagorilla's Avatar
Great, can't wait to see mine.
Old May 13, 2007 | 11:09 AM
  #24
WJ MARK's Avatar
Originally Posted by .T.
If you add a blower to a GM you might roach a piston there, too.
**** breaks.
Really want to make power? Buy a 2500 D-Max w/Allison and do the exhaust and program. It'll put out @ 600hp and 1000lb/ft tq. That's power!
I was eating those up all day at the track the other night.. Id stick with a gas motor
Old May 20, 2007 | 10:03 AM
  #25
QShip's Avatar
The two bottom pics are from my motor. Nissan has a known problem with their cats. They are known to break apart internally and get sucked into the motor.
Stillen claims that if there is any restriction within the the exhaust manifold and cats, it will raise the level of boost. With the ecu not able to enough fuel, it looked like a lean condition happened.
Due to the blower being on the motor when the cat went, Nissan Corp. would not touch it. I came out of pocket to get my truck back on the road.
I got rid of the stock cats and put some long tube headers on.
I would get rid of it and get something else, but I have too much money in the truck now.
Old May 20, 2007 | 12:09 PM
  #26
Spoolin's Avatar
GFYS and STFU
Wait, how does stuff get sucked in from the cats into the cylinders? That's going against the flow and "uphill". Just not understanding the how that can happen?
Old May 20, 2007 | 12:30 PM
  #27
markislive78's Avatar
13 Second Truck Club
It's time for "real" aftermarket support...The new plan is a 2wd Sierra Denali 6.2L 6-spd....I will put the Titan back to stock for trade in and sell the aftermarket Titan parts to peeps in forums...
Old May 20, 2007 | 12:33 PM
  #28
I think he mean't the cats were breaking up inside and eventually clogged which raised his boost and that what maybe cracked his piston....
Old May 20, 2007 | 12:37 PM
  #29
What I am finding out about the d-max is that the allison tranny is only good for an 80hp tune....anymore than that I hear you are running on borrowed time! I don't see the point in buying a 50k truck if I have to drop the tranny just to get it as fast as my Titan was NA...The 07' 2wd denali should get well into the 13's NA once the aftermarket support is there......To get a d-max into the 13's I would need a 1,300 dollar Tq converter installed and a shift kit in order to make it "reliable"...The Denali I want stickers for 41,900 I should be able to get them down to around 36-37k..
Old May 20, 2007 | 12:39 PM
  #30
Spoolin's Avatar
GFYS and STFU
I dont' think so, he said "They are known to break apart internally and get sucked into the motor." I understood the other part about the restrictive exhaust and faulty cats upping the boost and all but not about the stuff getting sucked in.
