What cracked these pitons?
Old May 9, 2007 | 08:41 AM
markislive78's Avatar
13 Second Truck Club
Default What cracked these pistons?
Hey Guys...What do yall think cracked these pistons? Boost(pressure) or tuning(detonation)? These pistons are from a Nissan Titan with a MP112 and only 6psi. So far we know of 3 folks who have blown motors while using the S/C and not so many folks out there with Titans and a S/C kit. The top 2 are pics are from the same truck and the bottom 2 are from a different truck both using the MP112 with a Stillen piggyback that comes with the kit. The reason for my concern is I also have a S/C Titan which is making a bad tapping noise from the bottom of the motor, the same noise the vehicle in the top 2 pictures was making. The piece that broke off in the top 2 pics was trapped in between the piston rings and that’s what caused his tapping noise. I am the very 1st Titan owner to go against the grain and use larger injectors and a custom tuned ECU for more flexibility with tuning vs using the piggyback and the extra injectors. When my motor started tapping I was data logging religiously, my AFR was 12 flat and my timing peak was 25 degrees BTDC. I also did not notice any detonation when my motor started making this noise.
Old May 9, 2007 | 08:54 AM
BlownChevy's Avatar
blownerator
25 Year Member
Broken rings/ringlands are an indication of extreme cylinder pressures. Was the boost turned up? Tank of bad gas?
Old May 9, 2007 | 08:57 AM
Thanks for the reply. This was only @ 6psi on all motors...I don't think we all had bad gas..lol! Does this just look like weak pistons that can't handle the boost or a truck that was running lean or detonating? The pistons aren't burnt or anything just cracked...
Old May 9, 2007 | 08:59 AM
NoRice's Avatar
well if it didnt ping and you are running normal boost, then they are just weak *** pistons
Old May 9, 2007 | 09:02 AM
No one with this problem noticed audible signs of detonation....I should have bought a Chevy....lol! What should I get a new next a new body style duramax or the new 2wd 6.2L 6spd Sierra Denali?
Old May 9, 2007 | 09:33 AM
camcojb's Avatar
ring gap too tight, like a tight gap on a non-boosted engine being subjected to boost. Rings meet and break the ring land on the piston.
Jody
Old May 9, 2007 | 09:51 AM
FastCrewCab4x4's Avatar
Detonation usually breaks the piston above the first (top) ring. thats interesting how those broke. Ring gap is a posibility though.
Old May 9, 2007 | 09:59 AM
camcojb's Avatar
one other thing is a lean condition is evidenced also. The area between the upper/lower ring is actually moved down, like the piston got very hot and had boost on top of it.
Jody
Old May 9, 2007 | 10:00 AM
hard to believe that you would have to rebuild an entire engine just to make it boost friendly
Old May 10, 2007 | 12:24 AM
jetmann's Avatar
I see this all the time,when you get your engine done and re-tuned make sure it is rich enough mid 11s A.F ratio under boost. Rex...........
