what belt to go with ??
Old Jul 17, 2010 | 01:10 PM
idahoblkss's Avatar
Default what belt to go with ??
well been researching a lil and not sure what belt i want to go with. ive been have belt slip issues and trying to fix the problem b4 dumping 2k into a 8rib set up... let me know what you guys are running preferably with s/c set ups and what has worked for you guys ... thanks
came across these what do you think ???
http://www.youtube.com/watch?v=vJtiK...layer_embedded
Old Jul 17, 2010 | 03:10 PM
Blown06's Avatar
8 Second Truck Club
A belt alone is not going to fix your problem with a 3.4" pulley.
Old Jul 17, 2010 | 03:18 PM
idahoblkss's Avatar
what about with a hd tensioner ?
Old Jul 17, 2010 | 04:27 PM
sharpshooter's Avatar
what procharger brackets do you have? the new or older style
Old Jul 17, 2010 | 05:37 PM
Rick_Vor's Avatar
Good call. Are you already running the newer "V-style" bracket? It moves the idler pulley closer the the head unit pulley and increases the belt wrap.
The bracket looks like this:
A second option is to run a Reichard Racing pulley. Great grip and 3.4" is a pretty common size for his Procharger pulleys.
Rick
Old Jul 17, 2010 | 06:33 PM
idahoblkss's Avatar
Rick
yes on both i got the newer brackets that put the head unit higher and away from the master cylinder , and i already have a 3.4 reichard racing pulley. how much are the hd tensioner from magna ?
Old Jul 17, 2010 | 06:45 PM
what length belt are you running?
Old Jul 17, 2010 | 08:16 PM
Rick_Vor's Avatar
I ran the same Goodyears belt for 20k miles (3.7" standard pulley) on a P-1SC @ 10lbs.
I went and picked up about 5 different length belts and used the belt that basically had to be pried on. I was within a 1/4" of max tension on the stock tensioner. Over time I built up a slight coating of belt dust around the pulley but boost was always rock solid at 10lbs at redline.
Rick
Old Jul 18, 2010 | 12:17 AM
idahoblkss's Avatar
its a napa micro-v 25-061130 not sure on the length of it thou what size should i be running you think ? maybe throw out some part numbers if you got them ... thanks
Old Jul 18, 2010 | 03:12 AM
Blown06's Avatar
8 Second Truck Club
With the RR pulley and an HD tensioner I think you'd be good to go. I had very good results with the Gates HD belt (its solid green on the back side and ugly) on RR pulleys. I'd call Joe at leftcoast32 for your HD tensioner needs. Probably run you about $350.
