Were to get a intercooler for my whipple
Old Nov 28, 2009 | 06:11 PM
  #51
06chevy5.3's Avatar
114lsa
Old Dec 1, 2009 | 07:19 PM
  #52
schino's Avatar
i wanna hear this thing. i bet its a lot louder and thinkin if its just blowin to air its prob not drawing to much more power. +1 for the corrado. i had one and those blowers are retarded loud. the throttle body is downstream and has a bypass built in. would divert air back to the intake side of the blower (heat soak the IC) guys puttin lysholms on these also run TB downstream as well... it sounds like a siren coming down the street
Old Feb 25, 2010 | 06:51 PM
  #53
MikeGyver's Avatar
Originally Posted by SincalT/A
I could figure out how much you'd gain approx. if you give me the vacum readings @WOT from the inlet elbow.
I am pulling 2-1/2 inches of vacuum at 6000 rpm at the blower inlet, between the blower and the throttle.
Old Feb 25, 2010 | 08:12 PM
  #54
SuperchargedSS's Avatar
lol...here I am thinking "when did Ben get a whipple??"
Old Feb 26, 2010 | 12:13 AM
  #55
SincalT/A's Avatar
I will say your down at least 75rwhp.Your gains will come from about 2#'s more boost + a reduction in iat's.
Old Feb 26, 2010 | 12:21 AM
  #56
SincalT/A's Avatar
I should elaborate more cause,most people think 2#'s that not going to net anywhere near 75rwhp.So understand there will be a huge flow increase causing you #'s to hp ratio to go up.Your probably going to gain some rpm too.
Old Feb 26, 2010 | 04:32 PM
  #57
MikeGyver's Avatar
That's a lot. What are you referencing that gives that kind of info? Will going to a 90 mm TB eliminate or just lower my restriction?
Old Feb 26, 2010 | 06:50 PM
  #58
SincalT/A's Avatar
My info comes from changing/testing the system on my truck.There is no way to figure exactly too many variables.Jus like i did by changing my system yours will benifit jus the same as mine.Probably more cause, you have more vacum at the inlet.
$A_Money$81
Mar 27, 2023 10:25 AM
turbo6c3
Oct 5, 2015 06:11 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
whippledstepside
Sep 17, 2015 05:02 AM
