Went for a drive tonight.
Old Jun 15, 2006 | 10:40 PM
Wilde Racing's Avatar
How do I change this text
I see it. How far in the intake does it sit? I wonder if my EGR block off plate would be restrictive?
Old Jun 16, 2006 | 08:05 AM
vanillagorilla's Avatar
That's pretty good idea. I just wonder if the f-body's IAT sensor is scaled the same as our factory one?
Old Jun 24, 2006 | 04:29 PM
MikeGyver's Avatar
Originally Posted by Mikegyver
Boost hits 7 psi at shift in 1st, hits 7 psi at high rpm in 2nd and starts dropping off to 6 at shift, stays at 6 in 3rd and starts tapering off to 5.
I took the duct tape off of the little added-on Whipple air filter that comes with the kit today. I taped it up last year because I thought that it might be contributing to high IATs by picking up hot engine compartment air. It wasn't, and that's what started the whole I/C project.
With the tape off, boost doesn't drop below 6psi and the truck keeps pulling instead of going flat at about 90 or so.
So now, with this information, I'll be starting a new project on the intake side of my S/C.
I'm going to move the MAF to the pressure side of the system, just ahead of the intake manifold. This will eliminate the MAF as a restriction, I'm sure it flows more than enough air to be on the pressure side.
Next will be a custom throttle-to-filter tube, eliminating the Whipple one.
And then the biggest cone-shaped K&N type filter I can get into the spot formerly occupied by the stock airbox.
I can't wait, it was so exciting to find why the boost was dropping off, and there is probably a lot more free (almost free) power available.
Old Jun 27, 2006 | 09:06 PM
MikeGyver's Avatar
This is the first step in making the increasers to put the MAF in my cool air pipe. The sizes are, starting at the MAF's entrance, 3" to 3 3/4", 4 1/8" to 3".
Old Jun 29, 2006 | 08:36 PM
MikeGyver's Avatar
Old Jun 29, 2006 | 10:12 PM
Whippled 496's Avatar
just like magic....looks good.
Sep 11, 2015 10:36 AM
MA$TER_E
Sep 9, 2015 03:14 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
