Went for a drive tonight.
Originally Posted by Wilde Racing
I see it. How far in the intake does it sit? I wonder if my EGR block off plate would be restrictive?
Originally Posted by Mikegyver
Boost hits 7 psi at shift in 1st, hits 7 psi at high rpm in 2nd and starts dropping off to 6 at shift, stays at 6 in 3rd and starts tapering off to 5.
With the tape off, boost doesn't drop below 6psi and the truck keeps pulling instead of going flat at about 90 or so.
So now, with this information, I'll be starting a new project on the intake side of my S/C.
I'm going to move the MAF to the pressure side of the system, just ahead of the intake manifold. This will eliminate the MAF as a restriction, I'm sure it flows more than enough air to be on the pressure side.
Next will be a custom throttle-to-filter tube, eliminating the Whipple one.
And then the biggest cone-shaped K&N type filter I can get into the spot formerly occupied by the stock airbox.
I can't wait, it was so exciting to find why the boost was dropping off, and there is probably a lot more free (almost free) power available.
MA$TER_E
Sep 9, 2015 03:14 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
