Welp there goes the 4.8
Old Mar 21, 2013 | 09:28 PM
holley2346's Avatar
Default Welp there goes the 4.8
Made ~600 on the dyno today, turned it up to 15 lbs. Made several pulls... by the end a/f looked great. No KR was logged with 16* of timing. On the last pull my crossover pipe broke, so after getting that fixed I headed home. The the truck was extremely fun to drive, like a brand new vehicle. About 10 miles from home I gave it a hit on a backroad and boom. Was running on a couple cylinders. I still had oil pressure so I kept driving home. Oil pressure went to 0 when I pulled into the yard.
Oil was everywhere.... I didn't see any holes in the block. And I was still able to make boost after it went boom. I also had no water by the time I got back. So my thinking is, blown head gaskets and missing the tops of some pistons?
Now what motor do I put back in it?
Old Mar 21, 2013 | 09:35 PM
GMCtrk's Avatar
That sucks. I'd go with a 5.3 or larger though for more out of boost oomph in that tahoe. What kit are you using?
Old Mar 21, 2013 | 09:37 PM
06murder's Avatar
Go back with 4.8 or get 5.3...
Old Mar 21, 2013 | 09:39 PM
holley2346's Avatar
Old Mar 21, 2013 | 09:50 PM
So what broke? Also what fuel are you using? 15psi was maxxing that 70mm out no doubt
Old Mar 21, 2013 | 09:51 PM
holley2346's Avatar
Boost held steady all day. I just got home an hour ago, I'll start tearing apart later. Premium pump gas + a hefty dose of boost juice.
Old Mar 21, 2013 | 10:01 PM
oakley6575's Avatar
Damn that sucks to see. In to see what went wrong.
Old Mar 21, 2013 | 10:50 PM
slammedsilvy's Avatar
No bueno. I'd like to know as well because I'm about to crank my boost up.
Old Mar 21, 2013 | 10:53 PM
TX Tahoe Z71's Avatar
Sorry to hear that, you were making some awesome power with that 4.8. I'd go 5.3 with a bigger turbo.
Old Mar 21, 2013 | 11:18 PM
stock48's Avatar
9 Second Truck Club
Sorry to hear that. 95% of the time I hear about a engine failure pump gas is involved. Sounds like it blew head gasket and coolant went into the oil. Cam is prob ok still. I would prob go with a 5.3L and lower the psi.
