weld els
Old Apr 25, 2014 | 08:40 PM
ullose272's Avatar
Default weld els
anyone know of a good place to get mild steel weld els?
Old Apr 25, 2014 | 08:44 PM
timmay208's Avatar
just curious why mild steel and not stainless?
Old Apr 25, 2014 | 09:24 PM
MikeGyver's Avatar
Ferguson Supply
Old Apr 25, 2014 | 10:14 PM
ullose272's Avatar
because i dont have the equipment to weld stainless
Old Apr 25, 2014 | 11:31 PM
timmay208's Avatar
ah do they require different welders? Im not a welder by any means but i know the guy that does my welding uses the same machine to do stainless as he does just mild steel
Old Apr 26, 2014 | 09:24 AM
ullose272's Avatar
it requires different wire and different gas, and you really shouldnt weld stainless and mild steel. i have 3 ls flanges and they are alll mild, so id be looking about $300 for wire, bottle and stainless parts. at that point i might as well buy the trick turbo manifold in swap meet. plenty of people use mild with success.
Old Apr 26, 2014 | 10:57 AM
TIM Z's Avatar
11 sec. Truck Mod
You can weld stainless to carbon steel no problem as long as you use stainless filler wire , preferably 316 SS .
OP try Columbia river for your bends. Or even fleabay.
Old Apr 26, 2014 | 02:05 PM
MIGHTY6's Avatar
McMaster Carr is where I get mine.
Old Apr 26, 2014 | 02:22 PM
BlackGMC's Avatar
Resident Retard
So what happens if you use regular wire to weld the to together?
Old Apr 26, 2014 | 06:06 PM
ullose272's Avatar
everything ive read says if you dont use the correct wire that it will crack and thats why you dont weld stainless to mild because it will not be the correct wire for on of the metals
