Weird problem
Old Dec 4, 2009 | 12:38 AM
  #31
Most Hated's Avatar
i think i found my problem, wen i tuned my truck i think my meth was not working so i tuned it like that then wen i disconnected the power to the meth the meth started leaking for some reason in the intake pipes , my ic was flooded , now i disconnected the meth from the intake and my af was at 11.0 11.2 all day long , but i checked my meth and doesn't seem to leak anymore, so i dunno , now im gonna tune it next week with meth to c how it works
Old Dec 4, 2009 | 07:14 AM
  #32
TURBHOE's Avatar
where is the tank and where is the fitting going into the pipes?? you may have started a syphon effect. your fitting HAS to be HIGHER than the water/meth upper level in the tank. if not it will just keep going and going. thats in big bold letters in my sts meth kit instructions.
Old Dec 4, 2009 | 03:04 PM
  #33
Most Hated's Avatar
i dont get it u can u be more specific
Old Dec 4, 2009 | 03:46 PM
  #34
lownslo's Avatar
if you have the nozzle below the pump it will gravity feed and the charge pipe will suck the meth out causing it to keep pulling meth out! If the meth is off and the i/c pipes are free of fluid and its running right then you need to get the tune set up for meth before you run it, and also make sure the meth kit doesn't have a faulty nozzle or bad pump!
Old Dec 5, 2009 | 12:42 AM
  #35
mike06tork's Avatar
is this in a speed density tune of MAF ? good luck getting it in the ball.
Old Dec 5, 2009 | 03:19 AM
  #36
Most Hated's Avatar
MAF well its workin on redrum,chochita,la blue,black blade ect.....
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
