Weird problem
Old Nov 30, 2009 | 03:12 AM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
If the regulator is going bad, it should lean you out, not richen.
Old Nov 30, 2009 | 03:13 AM
  #22
Do you have tuning software, or any way to log a run?
Old Nov 30, 2009 | 03:35 AM
  #23
Most Hated's Avatar
nope no tunning sof close by my tuner lives an hr away , so there's no way the fpr could be trowing more fuel than it should
Old Nov 30, 2009 | 03:44 AM
  #24
When it's working properly, at WOT it gives max fuel pressure. If not working properly, fuel pressure will be lower. Given the same injector PWM at a lower fuel pressure, should be leaner, not richer.
Old Nov 30, 2009 | 03:52 AM
  #25
Most Hated's Avatar
dawm i dont know wat to think now , the a/f was perfect all this time all of a sudden it started doing it this rich problem , i thought the a/f gauge was going bad but no u can really feel the slugishness at 9.9 af i even raced a camaro and the races were diff out come dependin on the a/f
Old Nov 30, 2009 | 03:53 AM
  #26
Most Hated's Avatar
bad maf ?
Old Dec 1, 2009 | 03:48 PM
  #27
phasemaster1's Avatar
One more try, did you change your belt after you had the truck tuned?
Old Dec 1, 2009 | 06:49 PM
  #28
1989k1500's Avatar
Sounds like the meth controller is ******* up to me.
Old Dec 1, 2009 | 08:36 PM
  #29
Most Hated's Avatar
but meth was disconected a still same out come
Old Dec 1, 2009 | 08:37 PM
  #30
Most Hated's Avatar
yes i put a tighter one
