Weird problem
Old Nov 29, 2009 | 03:09 PM
Most Hated's Avatar
positive i saw my gauge at 13psi with 9.9 a/f
Old Nov 29, 2009 | 06:19 PM
TURBHOE's Avatar
how far from the meth is the maf? every once in awhile i would have a small amount of spray blow to my maf when i let out. i have meth fire ***** blow out all the time when i lift after a hard run. not so much now that i have it tuned better though.
where is you vac source for your meth kit?
Old Nov 30, 2009 | 12:11 AM
Most Hated's Avatar
disconnected my meth kit still way too rich on some runs first run was 11.4-6 2nd run was 9.9 - 10.3
Old Nov 30, 2009 | 12:30 AM
rgvsierra's Avatar
did you ever put a fuel pressure guage?
Old Nov 30, 2009 | 12:33 AM
Most Hated's Avatar
on the left side of the intake it has a t and its connected to the bypass valve too
Old Nov 30, 2009 | 12:54 AM
Most Hated's Avatar
is there a possibility that my stock fuel pressure regulator is messing up ? i just ordered my fuel press gauge so it should be here this week hopefully to see where its att
Old Nov 30, 2009 | 02:20 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Marco, are you still running the tune from the Maggie setup? That could be part of it also, if you are. But at 13 psi, you should be speed density anyway.
Old Nov 30, 2009 | 03:04 AM
Most Hated's Avatar
no im on a new tune and the a/f was around 11.0-11.2 consistent the a/f problem barley started
Most Hated's Avatar
barely ordered it
Old Nov 30, 2009 | 03:06 AM
Most Hated's Avatar
i know a couple of friends still on maf and work great
