is water methonal injection worth it?
Old May 18, 2007 | 03:32 PM
xdanny510x's Avatar
Default is water methonal injection worth it?
is water methonal injection worth it? how much rwhp o rwtq should i expect?
Old May 18, 2007 | 04:07 PM
dbs1's Avatar
In and of itself it's not meant as a power adder. It will help detonation issues when running higher boost/ more cr. It helps you get to more power w/o fear of grenading your engine.
Old May 18, 2007 | 04:37 PM
.T.'s Avatar
.T.
It also requires some real good tuning to maximize the meth. I watched Dez spend over an hour last week dialing in a supercharged Mustang on the dyno. The car went from (something like) 320/330 to 380/390 with alot of fine tuning, timing and boost.
The big reality check (to me) was that meth is really only beneficial as the motor heats up.
Old May 18, 2007 | 10:42 PM
KY_BOB's Avatar
Do you ever really get to run a cold motor with no heat soak at the track?
Old May 18, 2007 | 11:49 PM
speedaddict's Avatar
i can't wait to drive my truck...I too just ordered a meth kit. I'm going to have Allen Nelson install and tune it.
Old May 19, 2007 | 08:49 AM
.T.'s Avatar
.T.
No, K-Y. Do you?
And with that blower you have, wouldn't you like to keep your IAT down? So spray some meth into it. But damn, there's a point where it works against you if your motor isn't hot enough. Hmmmm, guess everyone knows that.
Yes, at a point. Could be @60.
Old May 19, 2007 | 09:08 AM
KY_BOB's Avatar
No, K-Y. Do you?
I sure as heck don't. The meth keeps my IAT in the 125-130 range during a run. Without it, I have seen 180deg. You can imagine how much timing is being pulled at 180.
Old May 19, 2007 | 10:35 AM
FlaBouy's Avatar
I know the answer to that.... 10* on a stock motor.........
Old May 20, 2007 | 10:08 AM
QShip's Avatar
I was thinking about adding one to Stillen s/c Titan. The thing is the Stillen kit has a piggy back that is not tunable. That means that I can't tune via the ecu either.
The kit I was thinking about is tunable as far as the amount of meth to add. The name of the kit escapes me at the moment.
Do you think it's still worth getting the kit?
Old May 20, 2007 | 05:55 PM
dbs1's Avatar
Only if you get a gm LS kit to install in the titan also.
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Wrecker 426
Sep 29, 2015 11:00 PM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
