Wastegate upper banjo??
Old May 26, 2012 | 08:18 PM
urdone's Avatar
Default Wastegate upper banjo??
I have a resl quick question, I have a hose that goes in the upper banjo of tge wastegate trying to see where the hose goes from the upper banjo to.
Old May 26, 2012 | 11:42 PM
you should have a hose from the cold side before the throttle body going to the bottom side of the wg and a hose going from the cold side before the throttle body to a boost controller then to the top of the wg. By adjusting the boost controller you are varying the pressure on top of the diaphram of the wg and increasing or decreasing the boost pressure.
Old May 27, 2012 | 12:18 AM
urdone's Avatar
Yes that what i read in the instructions, but i dont have a boost controler.
Old May 27, 2012 | 12:44 AM
kbracing96's Avatar
Then you leave the top port open, as in nothing going to it but NOT plugged either. It needs to be able to "breath"
Old May 28, 2012 | 09:40 AM
yep! And just pick up a cheap manual controller. This is the one I have. Its cheap and gets the job done. Boost Controllers, Manual Boost Controller kit, RPS-BOOSTMAN | RacePartSolutions.com
Old May 28, 2012 | 12:21 PM
urdone's Avatar
So just leave it alone so it can breath.
What about the lower banjo?
Old May 28, 2012 | 12:28 PM
urdone's Avatar
And about the BOV is there a hose that i have to run to?
Old May 28, 2012 | 04:15 PM
You can leave both vented I believe and it will work off just the spring. And as far as the bov, run a vacuum line from after the throttle body to it
Old May 28, 2012 | 10:10 PM
kbracing96's Avatar
You only do that if you want to run about double the boost of what the spring is rated at ie 7psi spring will make 14psi of boost. The bottom port should be boost referenced. The blow off valve should be vac/boost referenced to the intake manifold after the throttle body.
Old May 28, 2012 | 11:04 PM
urdone's Avatar
I have a nnbs so what i did i run the lower banjo to the side of my intake and my BOV to.
