Wastegate spring?
Old May 8, 2009 | 05:52 PM
2ktransam's Avatar
Default Wastegate spring?
I am running a 8.4psi spring in my truck and it will only make 6psi running off the wastegate. It was making 6.5-7psi until I fixed a boost leak now it is down to 6psi. This thing has always ran about 1.5psi lower than the wastegate spring pressure but I don't understand why it got lower when I fixed the boost leak. Is this due to backpressure or what?
Old May 8, 2009 | 06:55 PM
FrostKing's Avatar
This is the pressure drop across the intercooler and piping if your wastegate is referenced at the turbo outlet instead of the intake manifold.
Old May 8, 2009 | 07:11 PM
2ktransam's Avatar
The wastegate is referenced from the intake. I'm not going to make it that easy. LOL
Old May 8, 2009 | 07:15 PM
SpoolinChevy's Avatar
Do you have a controller?
Old May 8, 2009 | 08:04 PM
2ktransam's Avatar
Yeah, I have the STS 0-15 electronic controller.
Old May 8, 2009 | 08:30 PM
TURBHOE's Avatar
how big is the wastegate??
Old May 8, 2009 | 08:37 PM
2ktransam's Avatar
I believe it is a 46mm. It's a knock off that I got from Kyle a long time ago and it looks like the Tial 46mm. I measured the opening in the wastegate and it is right around 46mm.
Old May 8, 2009 | 09:14 PM
bud8fan's Avatar
step up the controller..
i just installed mine today...running a 10# spring and have like 7.5# of boost in this heat...hooked up the manual turbosmart in cabin controller and turned it about 3/4 turn and i got my 10-10.5# of boost back....
Old May 8, 2009 | 09:20 PM
2ktransam's Avatar
I have high boost set on 13.5psi right now. I'm wanting to run 7-8 on low boost but I don't want to buy another wastegate spring. I already have a 5.5, 7.2 and 8.4psi springs and I don't feel like spending another $35 to get a 10psi just to run 7.5psi off of the wastegate.
Old May 8, 2009 | 09:36 PM
TURBHOE's Avatar
maybe its just bleeding off alot of exhaust being that the gates huge. i have a 7psi spring in a 36mm gate and run 10psi.
