wastegate and bov hookup
Old 06-26-2012, 11:21 AM
  #41
graysilverado5.3's Avatar
Originally Posted by Atomic
Mine is sealed right there...you would have to drill out a hole if you want to use that. I use the brake boost fitting on the back since I have hydroboost.
I did the same also.
Old 06-26-2012, 01:18 PM
  #42
02'Z71ONDUBZ''s Avatar
Originally Posted by Chevy Cowboy
this is the only place I see to connect the vacuum line too, but I dont see how the cover or whatever is pluggin the hole comes off?
Just grab the plastic tab and break it off with your fingers, then slide the hose up on it. No need for drilling anything. Thats where my boost gauge and bov are hooked up. Obviously the brake booster line will work fine as well.
Just saw that was a nnbs intake, it might be a bit different but it looks about the same.
Old 06-26-2012, 01:42 PM
  #43
Gingervitis Addict
slow67's Avatar
Not saying this WILL happen, but its possible.
Also there is no seal on the valve, so it is a vacuum leak (pulling in small amounts of exhaust fumes, or being pushed in if backpressure is higher).
Old 06-26-2012, 05:29 PM
  #44
stoicho315's Avatar
Ok thanks, i saw that and was gonna just go for it and break the end off but thought id ask first, thinks running all three, wastegate, bov and gauge would work fine there?
Old 06-26-2012, 07:05 PM
  #45
holley2346's Avatar
Running all 3 off that same port. Works great.
GMCtrk
10-20-2015 06:17 AM
LSX-81-SIERRA
10-02-2015 07:05 AM
Tuckin15s
09-23-2015 09:35 PM
97_ek
09-23-2015 09:16 PM
Quick Reply: wastegate and bov hookup
