Want to Turbo my 6.2L
Old Mar 27, 2017 | 11:24 PM
dcn92's Avatar
Post Want to Turbo my 6.2L
Im looking to put a turbo on my 2011 Silverado, what all do I need to do in order to turbo it?
Old Mar 27, 2017 | 11:32 PM
FFDP's Avatar
Lots of readings for sure.
A turbo kit, large fuel injectors (like 70lb/hr or higher depending on power wanted), fuel pump (again depending on power level wanted, stock flex fuel pumps are good for around 550whp give or take), built driveshaft, new rear locker as the G80 will explode. 2-3 bar MAP sensor, wideband and tons of other odds and ends.
Take some time and research this stuff a little and you'll figure most of it out.
Old Mar 27, 2017 | 11:35 PM
dcn92's Avatar
Okay thanks, the driveline of my truck is of a 2500 but its just got the 6.2. So I got the 4L80 tranny and bigger drive shaft, transfer case, and 14 bolt Rear end
Old Mar 28, 2017 | 08:18 AM
TrickTurbo's Avatar
Truck Sponsor
Our STage 5 kit. Larger injectors, final exhaust, good solid tuning is must, then your misc stuff which is what you want the look to be. Gauges in the truck.
It can be a simple set up or over the top complicated depending on your goals for the truck.
Old Mar 28, 2017 | 07:52 PM
FFDP's Avatar
Just a FYI, a 2011 Silverado with a 6.2 has a 6L80e stock. They never came with 4L80e's unless you swapped it out yourself.
Old Mar 28, 2017 | 10:27 PM
dcn92's Avatar
How much is your Stage 5 kit?
Old Mar 28, 2017 | 10:29 PM
dcn92's Avatar
Yeah thats what I meant lol
Old Mar 29, 2017 | 06:52 AM
TrickTurbo's Avatar
Truck Sponsor
5300.00 and we
can upgrade to a 4" race inter cooler for 200.00 more.
Old Mar 30, 2017 | 08:32 AM
If the 2500 driveline included transmission you have a 6L90E....
Old Mar 30, 2017 | 10:20 AM
Choda's Avatar
a turbo kit from trick and 60lb or higher lb injectors. That will get you off to a killer start. you wont make killer power because of the big wheels and tires but it'll def wake up and you'll love the turbo sound.
