A/W intercooler ?
I was thinking about getting a purge kit that would run to my A/W intercooler.
I would unhook the water and put a new fitting on it the intercooler so that the N02 could go though it. Then I would hook the purge power wire to my meth kit so that when my meth comes on it would shoot N02 though the intercooler.
I feel that a spray bar for my heat exchange wouldn’t help much but this should make my air to water an air to N02.
This would be for hot track days and I would be going for way below ambient temps
Has any one done this? I bet it would help you radix guys out a lot.
Ok you will need to put a restrictor jet in the inlet fitting for this to work. We have taken a tranny cooler put into water to see just how much we could chill the water. The coolest we could get the water was 70'. That wasted 1 bottle of co2 cheaper then nitrous
and really was not worth it. You have to start the nitrous really soon to get the tubes to start chilling a bunch.
YOu are way better off setting up a water tank that you can circulate the water over ICE then to the intercooler. A simple set up would have some 3 way valves so while at the track you are just move water through the ICE not to the heat exchanger in the front.
We build a tank that fits into the passenger side rear corner of the engine bay, roughly 1.5 gallons.
Rick
and really was not worth it. You have to start the nitrous really soon to get the tubes to start chilling a bunch.YOu are way better off setting up a water tank that you can circulate the water over ICE then to the intercooler. A simple set up would have some 3 way valves so while at the track you are just move water through the ICE not to the heat exchanger in the front.
Rick
i agree. i have a intercooler spray bar and it does next to nothing. after i figured out i was wasting my nitrous i installed a small 3 gallon fuel cell in place of my orignal air box and i can get the iat way below ambient , an ice box is where its at with a/w intercoolers.
