vic jr on 370
Old Jan 24, 2007 | 10:48 PM
2004SSS's Avatar
Default vic jr on 370
im lookign at possibly adding a vic jr on my new 370 motor. the rason im looking into the vic jr is because of cost and also i need something with new larger fuel rail to support a new fuel system. im going to have a new intake elbow made for it so i can mount a 90 mm tb on it and keep the same mounting spots as the truck intake manifold since my vortech boost tube is right above the tb on the track intake. i want to know how well it will work on a 370? i know they are meant for a larger cube motors but since im going to be flowing more air than a big cube (15 psi) i figure it might help not to mention distribute air better than my truck intake. im just wondering how much low end will i lose due to the shorter intake runners? any thoughts?
it should look similar to this
Old Jan 24, 2007 | 10:54 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I think it would work great, especially with the boost.
Old Jan 24, 2007 | 10:58 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You might loose some daily driver torque, but not much. Mostly the Vic Jr's range rating is based on a carb setup. For EFI, the lower range goes to 1400rpm or something like that.
Old Jan 24, 2007 | 11:06 PM
thunderwagen's Avatar
I think with the amount of boost you are wanting to run it is insurance against killing #7. I am going to be doing one on the 370 I am getting ready to build for the new turbo setup.
Old Jan 24, 2007 | 11:53 PM
2004SSS's Avatar
good to hear guys hopfully get this pig running soon. it should be good with everythign i have planned as of now but the 65 e is going to be my barrier
Old Jan 25, 2007 | 12:17 AM
do it!!!!
Old Jan 25, 2007 | 02:11 AM
2004SSS's Avatar
does nayon eknow what the speartech harness for the 90mm tb consist of? is it possible to make one myself?
Old Jan 25, 2007 | 04:01 PM
I have one that I was planing on using on my radix set up that im not going to use anymore. it is new never used I will make you a deal on it.
kainzien
Nov 10, 2023 11:37 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
OHsixLS3
Sep 25, 2015 04:38 PM
OHsixLS3
Sep 25, 2015 11:20 AM
97_ek
Sep 23, 2015 09:16 PM
