Very Little Boost...8.1L Rear Mount
Old May 14, 2009 | 08:29 PM
Ender06's Avatar
Default Very Little Boost...8.1L Rear Mount (Video Added, Poor Quality)
OK, got the turbo on, and I am seeing very little to no boost. And lag is horrible. I have two wastegates before the 76mm Precision Turbo. Springs are .2bar, so like 3-4lbs springs. With both wastegates hooked up, I am seing like 1 pound of boost, and NO WASTGATES, I see like a max of 6-7lbs. Shouldn't this thing be able to make like 20 lbs. And I see NOTHING in 1st gear, no matter what, but second i can see bout 3 lbs, and 3rd and up like 6-7. That is with NO wastegates at all. Is it maybe a major Boost leak that i am just not seeing??
Old May 14, 2009 | 08:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd go over the cold side with a fine tooth comb.... that much piping and the possibilities are just about endless for a leak... do you have a big restriction maybe before the turbo???
Old May 14, 2009 | 08:40 PM
Ender06's Avatar
No real restrictions, just the cats, and those are 2 BIG converters
Old May 14, 2009 | 08:43 PM
Hunt&Fisherator
I'd NEVER recommend running a catalytic converter before the turbine... if that thing comes apart, your turbo's done.
I was mainly talking about pre turbo, on the cold side.
Old May 14, 2009 | 08:45 PM
Ender06's Avatar
OH, then no, nothing before
Old May 14, 2009 | 08:51 PM
Hunt&Fisherator
that size turbo with those cubes should give you almost instant boost. and max at maybe 8psi? not sure the exact one you used but I'd say thats definitely not right.
Old May 14, 2009 | 09:03 PM
1BADAZZSS's Avatar
If a piston comes apart the turbo is gone too
Old May 14, 2009 | 09:08 PM
Ender06's Avatar
Don't jinx me now
1BADAZZSS's Avatar
Tierods truck spiked to 17# before with the precision 76. What size wastegates you runnin? Also have you tried to compress air into the charge side? Might be having a leak somewhere in the charge pipe.
Old May 14, 2009 | 09:11 PM
Ender06's Avatar
Yea, i think it has to be a leak, but just checking the possibilities. Wastegates are two 38mm
